- Level
- AMC
This product is not manufactured or distributed by StudioDaydream, maker of the StudioDaydream Dhyana or Smoky Signal Audio, maker of the Smoky Signal Tubeless Overdrive.
PedalPCB is in no way affiliated with StudioDaydream or Smoky Signal Audio.
cgmason1986 (verified owner) –
Awesome sounding pedal! This my third dumble style pedal that I have built. This is by far the most quiet. With everyone at noon I’m less than unity gain. The volume doesn’t really start to kick in until about 2 o’clock. The modifications that I would make if you are going to do this would be 1 – reverse log volume pot and a reverse log AMC pot – this seems like a high-pass filter, and below 12 is just too muddy (for me).
tcoffel (verified owner) –
Seriously amazong sounding Dumble Drive / Zen Drive sound. I have a few Dumble Drive style pedals, and this sound the BEST out of all of them (and the ones I have sound killer BTW). It has that Dumble chime ran through a Clean amp that I crave when playing certain styles. You can crank the GAIN and the A.M.C. about 3/4 of the way up, and get a bad ass lead tone as well (adjust your Tone knob to suit) with a grunt behind it. This pedal will absolutely be a STAPLE on my board!
SIDE NOTE: I tried both the AD chip, and a TL072 OPAMP.. The TL072 will provide you a little darker sound to the tones, which will require a bit higher Tone sweep and A.M.C. setting, but worth a try to see what you think. I almost prefer the TL072 sound to the other. I will probably build a second one and run one with the AD chip and one with the TL072 to be honest. GETCHEW ONE!
