B-STOCK
This board will have minor cosmetic defects (smudged silkscreen, scratched soldermask, etc) but will still be fully functional.
Base PCB only, no breadboards, components or hardware are included.
Breadboards
Supports dual 830-point solderless breadboards offer plenty of room for prototyping.
Integrated Power Supplies
- GND
- +4.5VDC Reference
- +5VDC
- +9VDC
- -9VDC
- +18VDC Charge Pump
Quick Change Potentiometers
Screw terminals allow instant swapping of standard 16mm right angle pin potentiometers. No soldering, special pots, or adapter PCBs required.
Signal Routing / Bypass
- True Bypass switching
- Circuit input grounding in bypass to eliminate effects bleedover
