Germanium DiodesView All
PartPrice
D9B Germanium Diode
D9B Germanium Diode$1.00
1N192 Germanium Diode
1N192 Germanium Diode$1.00
D9L Germanium Diode
D9L Germanium Diode$1.00
D9A Germanium Diode
D9A Germanium Diode$1.00
D9D Germanium Diode
D9D Germanium Diode$1.00
D9E Germanium Diode
D9E Germanium Diode$2.00
D9G Germanium Diode
D9G Germanium Diode$1.00
D9J Germanium Diode
D9J Germanium Diode$1.00
D9K Germanium Diode
D9K Germanium Diode$1.00
D9V Germanium Diode
D9V Germanium Diode$1.00
Zener DiodesView All
PartPrice
1N4678 1.8V 1/2W Zener Diode
1N4678 1.8V 1/2W Zener Diode$0.95
1N5223B 2.7V 1/2W Zener Diode
1N5223B 2.7V 1/2W Zener Diode$0.50
1N5226B 3.3V 1/2W Zener Diode
1N5226B 3.3V 1/2W Zener Diode$0.50
1N5227B 3.6V 1/2W Zener Diode
1N5227B 3.6V 1/2W Zener Diode$0.50
1N5231B 5.1V 1/2W Zener Diode
1N5231B 5.1V 1/2W Zener Diode$0.50
1N5239B 9.1V 1/2W Zener Diode
1N5239B 9.1V 1/2W Zener Diode$0.50
1N5242B 12V 1/2W Zener Diode
1N5242B 12V 1/2W Zener Diode$0.50
1N4748A 22V 1W Zener Diode
1N4748A 22V 1W Zener Diode$0.50
1N5232B 5.6V 1/2W Zener Diode
1N5232B 5.6V 1/2W Zener Diode$0.50
Silicon DiodesView All
PartPrice
BAT41 Small Signal Schottky Diode
BAT41 Small Signal Schottky Diode$0.15
BAT42 Small Signal Schottky Diode
BAT42 Small Signal Schottky Diode$0.15
BAT43 Small Signal Schottky Diode
BAT43 Small Signal Schottky Diode$0.15
BAT46 Small Signal Schottky Diode
BAT46 Small Signal Schottky Diode$0.15
2D503B Silicon Pulse Diode
2D503B Silicon Pulse Diode$0.75
1S1588 Silicon Switching Diode
1S1588 Silicon Switching Diode$1.00
BAT48 Small Signal Schottky Diode
BAT48 Small Signal Schottky Diode$0.15
1N5817 Schottky Power Rectifier
1N5817 Schottky Power Rectifier$0.25
New ArrivalsView All
NEW!
$12.00
Compare to Strymon Canoga Fuzz
NEW!
$10.00
Compare to Pedaltrain Nightlight Distortion / Daylight Overdrive
NEW!
$12.00
Compare to Awptweaker Depth Finder
NEW!
OD / Distortion / Fuzz
Revision Overdrive
$12.00
Compare to TWA Source Code Overdrive
NEW!
$12.00
Compare to Buffalo FX RH-X '76
NEW!
$12.00
Compare to Keeley Moon Op Amp Fuzz
NEW!
Dog Byte Fuzz
(1) $8.00
Compare to Mellowtone Wolf Computer
NEW!
Glue Trap Fuzz
$12.00
Compare to Greer Amps TarPit Fuzz
NEW!
Sheepylove Frizzler Distortion
$12.00
Sheepylove
NEW!
Sheepylove Hot Teacher Overdrive
$12.00
Sheepylove
NEW!
Sheepylove Hebridean Overdrive
$12.00
Sheepylove
NEW!
EQ / Filter
Referee EQ
(1) $12.00
Compare to Broughton Audio Resonant Filter Equalizer
NEW!
Deep End Fuzz
$12.00
Compare to Prescription Electronics Depth Charge
NEW!
Tone Zester Boost
$12.00
Compare to J.Rockett Lemon Aid Boost
NEW!
Overcast Fuzz
$10.00
Compare to Circle Electric Co. Spirit in the Sky Fuzz
NEW!
$12.00
Compare to MXR Super Comp
Featured
Out of stock
(8) $8.00
Compare to ProCo Rat
(3) $10.00
Compare to DUMBLE® BBC-1 / JHS FUMBLE Boost
Modulation
Caesar Chorus
(13) $12.00
Compare to Walrus Audio Julia
ElectroSmith Daisy
Terrarium
(6) $12.00
Electrosmith Daisy Interface
Upcoming ReleasesView All
COMING SOON
Out of stock
Coming Soon
Wicked Muffin Fuzz
$12.00
Compare to EHX Big Muff Pi with Tone Wicker
COMING SOON
Out of stock
$10.00
Compare to JHS Box It Later / DUMBLE® A Box Later
COMING SOON
Out of stock
Coming Soon
PedalPCB Tuner
$0.00
Guitar Tuner
COMING SOON
Out of stock
$12.00
Compare to Octaking Burstphonic PAF
COMING SOON
Out of stock
$0.00
Guitar Tuner
COMING SOON
Out of stock
Faceplates
Tuner Faceplate
$5.00
Cosmetic Faceplate
COMING SOON
Out of stock
Pondhopper Overdrive
$12.00
Compare to EHX Spruce Goose Overdrive
Most Popular
Breakout Boards
3PDT Breakout Board
$0.50
Basic grounding input bypass 3PDT breakout board
$0.50
SOT23 Adapter
$0.50
Power Breakout Board
Out of stock
$1.00
N-Channel JFET
Components
TL072CP
$1.00
Dual Op-Amp
$1.00
3PDT Effects Order Switcher
Utility
Trimmit!
$0.50
Trim pot adapter
$1.00
Illuminated 3PDT breakout board
